cant connect to comfort via app or comfigurator - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Thread: cant connect to comfort via app or comfigurator (/thread-4581.html) Pages:
1
- slychiu - 12-17-2016 Ah yes, I have seen this befoire. Sometimes Bus monitor mode on UCM/ETH03 does not exit properly. The symptom is the Red D0 LED on the UCM is blinking gas but the green led is off. Resetting the UCM will fix this. But what is a UCM Venus? - wexfordman - 12-17-2016 [user=1]slychiu[/user] wrote: Quote:Ah yes, I have seen this befoire. Sometimes Bus monitor mode on UCM/ETH03 does not exit properly. The symptom is the Red D0 LED on the UCM is blinking gas but the green led is off. Resetting the UCM will fix this. Sorry, auto correct, I meant ucm velbus :-) |
