Sunset Curtain Control - Help needed - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Programming Comfort (https://www.comfortforums.com/forum-83.html) +--- Thread: Sunset Curtain Control - Help needed (/thread-4952.html) |
- slychiu - 07-10-2020 I would do a fulll write to Comfort to ensure that everything in Comfort is corectWgen the nigfht flag turns on, so should the sunset response - Ian - 07-10-2020 I did a full write to Comfort a couple of hours before Sunset. - slychiu - 07-11-2020 we will do some testing on this and let you know the result - Ian - 07-11-2020 Thank you. - slychiu - 07-13-2020 We have confirmed that the Sunset response is not written to Comfort by Comfigurator, so it does not work, Sunrise response does work This should be fixed in the next version. Thanks for the feedback In the meantime please use other workaround like Time Programs - pete_s_h - 07-13-2020 I too have not been able to get my curtains to close using the Miscellaneous Events Sunset Response being linked to CloseCurtains although I think this is the way I did it before my recent Comfort problems. I have been following the experience of Ian and the your conclusion that Comfort is not writing the Sunset Response to Comfort. Is this just problem with Comfigurator 3.13.3? I still have copies of 3.12.16, 3.12.12, 3.12.8. I will try reloading these to see if I can get the automatic Sunrise/Sunset Table time to close the curtains and report my findings.Thanks for all the information so far. - slychiu - 07-16-2020 As this issue may affect many users which need the Sunset Response, the new version Comfigurator 3.13.4 fixes the problem. Please download from https://www.cytech.biz/product_details.php?item_id=206 and test - slychiu - 07-17-2020 In order to get the sunset response working after upgrading to 3.13.4, please write the sunset Response to Comfort again - Ian - 07-18-2020 I can confirm that it is now working for me :-) - pete_s_h - 07-18-2020 Success!Thanks for the new version of Comfigurator. I have installed and reloaded my cclx file to Comfort and now the curtains close at sunset as they are supposed to do.Thanks again. |
