buggy timer behaviour - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: buggy timer behaviour (/thread-5066.html) Pages:
1
- slychiu - 08-04-2019 Thanks for the Bus Monitor files. These revealed the cause of the problem. Output 4 was set low when Sensor 3 value was received from the TSM temperature sensor. In Functions > Thermostats, Output 3 was assigned to the thermostat. However there is an undocumentated feature where the next output is controlled by the thermostat, so that output 4 was affected. Hence the problem was not due to timers. Timers are working properly. To work around the problem use another output other than 4 for the light or assign another output for the thermostat in which the next higher output is not used. The next firmware will fix this bug - 2dp - 08-04-2019 Thanks for your patience, persistance and help! ![]() |
