Firmware Upgrading System failure - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Firmware Upgrading Problems (https://www.comfortforums.com/forum-111.html) +---- Thread: Firmware Upgrading System failure (/thread-5069.html) Pages:
1
- slychiu - 06-11-2019 It seems you may be trying to log in. Do Not Log in Remember to Short PP2 shunt before trying Go to Transfer > Firmware Upgrade using UCM Firmware cable Then select the File The upgrade will start - raygregg114 - 06-11-2019 double checked all cables and still getting same message. PP2 shunt is in place and i am not logging on. When i right click on the controller and do download firmware upgrade a message appears saying unable to obtain upgrade information. Siren is going and keypads are beeping as per instructions. - slychiu - 06-11-2019 Downloqad the firmware from here https://www.cytech.biz/comfort_ultra_firmware.html - raygregg114 - 06-11-2019 File 7.153 downloaded to PC but still getting message about UCM settings as previous - slychiu - 06-17-2019 This is an update on the problem reported. UCM/ETH02 does not work when upgrading Firmware by right-Clicking on the module and selecting Upgrade. UCM/ETH02 was discontinued many years ago and does not support this newer function. This is why the initial Firmware upgrade did not work. UCM/Eth02 can only do the upgrade by UCM Firmware Upgrade cable. This method managed to upgrade the ULT Firmware and get the system back to normal - raygregg114 - 06-19-2019 Changed to GSM4(3g) yesterday and working fine will change to ETH03 later today. - raygregg114 - 06-19-2019 Upgraded to ETH03. all went well and unit is getting IP address. When i scan for modules i get the message --------------------------- Comfigurator --------------------------- Failed to connect to UCM - please check the UCM Connection Settings --------------------------- When i go back into the ETH03 it has the IP address and is at current software version. - raygregg114 - 06-19-2019 SORTED. Comfort not set to same IP Address as ETH03. Changed and all working as normal. |
