Not able to write PC to comfort - Printable Version
+---- Thread: Not able to write PC to comfort (/thread-5134.html)
Pages: 1 2
- Home - 01-07-2020
Would be good to get some feedback on the android app!
- beighmuddassir - 01-12-2020
So far I have not encountered any major issue on android app.
Works seamlessly while I am on LAN.
I am having trouble using remote access, would appreciate if someone could direct me to a thread on remote access setup and port forwarding. I have tried DynDNS and Noip but I am not able to log in while away from home.
Many thanks
- slychiu - 01-13-2020
You need to set up port forwardibng on your router to forward an Internet IP Port to your locak IP address and PortThe way to do it depends on your routersee an example of the Asus router here https://portforward.com/asus/rt-ac68u/
The guide shows you how to set up a fixed IP address on your computer. Ignore this, you need to have a fixed IP address in UCM/ETH03 via Comfort server manager
- beighmuddassir - 01-14-2020
Thanks, port forwarding worked and I have remote access now!
It ay be helpful for futures users to know that to use port 1001 or 1002 in your router for port forwarding because they are the default ports for ETH03.
- slychiu - 01-14-2020
It is a good iodea to use higher numbered ports to reduce the chance of someone guessing the port
