ISM07 input as virtual input - Printable Version
+--- Forum: Questions on Programming Comfort (https://www.comfortforums.com/forum-83.html)
+--- Thread: ISM07 input as virtual input (/thread-5512.html)
Pages: 1 2 3 4
- Howser - 09-19-2024
However at times when input 95 or 96  detects motion at the same time that the inputs on the LEM are shorted, then zone trouble is announced.
- slychiu - 09-20-2024
can you change the viruial inputs from 95 and 96 to another unused zone eg   zone 65 and 66. does the zone trouble change
If you have the latest firmware and Comfigurator, you can trigger virtual inputs on and off using I! in Comfigurator.  eg  I!6001 Input 96 On,  I!6000 Input 96 Off I!5F01 Input 95 On
I!5F00 Input 95 Off
You can test this with Zones 14 to 16 in on and off state. i could not find any instnace of zone trouble
- Howser - 09-20-2024
[font=\"Verdana, sans-serif\"][size=\"3\"]Investigation 1[/size][/font][font=\"Verdana, sans-serif\"][size=\"3\"]
[/size]
Quote:can you change the viruial inputs from 95 and 96 to another unused zone eg   zone 65 and 66. does the zone trouble change
[/font][font=\"Verdana, sans-serif\"]Zone trouble is still happening.
Code:
09/20 13:58 Alarm Type # ZoneTrouble (5)
09/20 13:58 Zone Trouble # XXXXXXX_PIR (16)
[line][size=\"3\"]
Investigation 2
[/size]
Quote:If you have the latest firmware and Comfigurator, you can trigger virtual inputs on and off using I! in Comfigurator.  eg  I!6001 Input 96 On,  I!6000 Input 96 Off I!5F01 Input 95 On I!5F00 Input 95 Off
I tested this and once the virtual Input is active, then I get Zone trouble when the PIRs are triggered. But, it only reports the zone trouble once for each active cycle, no matter how long I keep the virtual input active for.[/font]
- slychiu - 09-23-2024
We found a bug in handling of LEM zones, but not sure if it is to do with your particulr problem. Can you upgrade to ULTA 8.008 using this link https://www.cytech.biz/download_files.php?item_id=1415
However from your cclx file your 1st ucm is 7.150. Please upgrade to the latest version otherwise you will not be able to do the upgrade to the Ultra comfort firmware
Let me know if you still have the zone trouble problem
- Howser - 09-23-2024
I tried upgrading the first UCM to 7.225, downloaded the local file, started the upgrade.
 After completing the upgrade the version on Comfigurator is still showing 7.150.
Below is Comfort Version screenshot.
[img]data:image/png;base64,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[/img]
- slychiu - 09-24-2024
Your screenshot shows you are upgrading the UCM firmware to 7.225, but you also have to upgrade the Controller to 8.008 next.  In short there are 2 upgrade operations, UCM, then Controller
- Howser - 09-24-2024
The UCM did not upgrade, the upgrade process went through, but it still shows version 7.150.
[img]data:image/png;base64,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[/img]
- slychiu - 09-25-2024
sorry I misunderstood your previous email, You completed the UCM upgrade to 7,225 without error but the version is still 7.150?
Did you right click on the UCM and select Check for Firmware upgrades as in the image below?
If the upgrade completes without errors, then you have top scan for modules again to show the updated firmware version
- Howser - 09-25-2024
That option is not available
[img]data:image/png;base64,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[/img]
Yes, I scanned for module after Comfigurator showed that the firmware was upgraded.
