Problem upgrading KP04A - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Firmware Upgrading Problems (https://www.comfortforums.com/forum-111.html) +---- Thread: Problem upgrading KP04A (/thread-5519.html) Pages:
1
RE: - Majik - 09-17-2025 (11-29-2024, 11:11 AM)slychiu Wrote: Can you try power off and on. ? Sorry about the radio silence on this, but I wanted to try a few things out, and I've also been travelling. When I try to use the bus monitor, I don't get anything at all appearing in the monitor window. I'm using an Eth3 directly mounted on the main board. Do I need to use a separate UCM to make the bus monitor work? Cheers, Keith RE: - Majik - 09-28-2025 *BUMP* RE: Problem upgrading KP04A - slychiu - 09-29-2025 sorry this new forum has some issues with reply notifications. The Comfort BusMonitor does not work when ETH03 is plugged in to the CM9001. Do you have another UCM with USB or eth03? RE: Problem upgrading KP04A - Majik - 10-05-2025 (09-29-2025, 05:52 AM)slychiu Wrote: sorry this new forum has some issues with reply notifications. The Comfort BusMonitor does not work when ETH03 is plugged in to the CM9001. Do you have another UCM with USB or eth03? I do. I will have to dig it out. Please bear with me as I have other things to deal with. Cheers, Keith |
