ETH3 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Thread: ETH3 (/thread-5613.html) Pages:
1
- jbarne41 - 03-21-2025 Hi Chiu, Ok, so is the Issue that I have set the RS232 UCM as ID 02? Should the Eth03 that is plugged into the mainboard show up as a UCM in the module list as per my configurator screenshot. Apart from the dropping connection my other problem is I cannot edit anything in the server manager where it just flashes rapidly. - slychiu - 03-21-2025 No, setting the UCM/232 as ID2 should not affect the eth03 on CM9001 Comfigurator sometumes gets cinfused about the eth03 plugged unto the CM9001, t should report the UCM in Controller properties not ucm properties, but that does not cause the problemI suggest to getr another ETH03 submoduleto plug on to the UCM/232 to replace the rs232 if you are not using the Rs232 anymore This will confirm if the original ETH03 is faulty - jbarne41 - 03-27-2025 Hi Chiu, Spent the £80 odd to buy another ET03, fitted it to the Spare UCM base board I have ( I still use the Serial 232 to send messages to and from my Homevision system) I removed the original Eth03 from the comfort mainboard and connected the UCM via a spare slot on the ADM02, still get the same results...Comfort server manager still flashing. The only difference was that I the iPhone App would open and close straight away with the the ethernet cable plugged into the Etho3? I am wondering if this might be a wiring issue.......since I replaced the whole of the system and added two Slave Expansion modules I have also had the following Issues that I am still to resolve.....the Volume on both Keypads is very low compared to what is used to be I have raised the levels in the setting but has made no difference. The other issue is I cannot hear people on the door station when the doorbell is pressed. I have also noticed that in configurator the UCM Logo in the corner also pulses...is this normal? Regards Joules - slychiu - 03-28-2025 You mean you have the same problem now on both eth03 plugged in to different boards? That seems like a network issue or perhaps the power supply is intermittent? or something interfering with the connections? UCM logo flashing is not normal But you can use comfigurator to write and rad to comfort without getting interrupted? Maybe the problem is with the iphone? - jbarne41 - 03-28-2025 Hi Chiu, Yes, different ET03s plugged into separate base board and plugged into Comfort main board cause same issue of the][size=the flashing in Comfort Server manager. Can read and download into Comfort Ok iPhone app works fine with the ETH03 plugged into comfort main board, don\'t think iPhone is issue and defiantly wouldn\'t cause flashing on Comfort Server Manager. As stated since the the upgrade of all new comfort main board and adding new Slave Expansion boards new door station module, relay boards and ADM02, I have had issue with low volume on keypads and no mic on door station.One other issue is I cannot get the Strobe to work off one of the remote slave panels. Think my next step will be to disconnect components to see if it solves the issue. Regards Joules |
