New messages on Answering machine do not turn on MSG Led - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: New messages on Answering machine do not turn on MSG Led (/thread-768.html) Pages:
1
- Home - 04-20-2007 So are you able to replicate the problem? Any sign of a fix! - slychiu - 04-21-2007 No, we find that all recorded messages ALWAYS turn on the message light. Is there anything else you can tell us, eg are the messages very short? or very long? is there anything special about the telephone line etc? Does this always happen, or has it started only recently? - palmlodge - 04-21-2007 I\'ve had this problem for quite a while. Dont know we have messages until we next sign in. And sometimes it says \"Day 8 pm\" after listening and deleting the last message. Running 5.075 - ident - 04-21-2007 Its frustrating not to be able to see the same problems as faced by users. Once we can duplicate, it will be a simple matter to correct. BTW You do not have to sign in to know if you have messages. You can just press the # key by itself. Comfort will announce \"new message for ..\" or \"No Message\" - Home - 04-21-2007 This was an upgrade i.e it has a \'U1\' firmware PCB inserted - it sounds as though palmlodge is the same - ident - 04-21-2007 Home said.. Quote:Would a copy of the ccl file help! It may. Please send it - ident - 04-22-2007 Perhaps we have been looking at the wrong angle. Have you verified that when you remotely record a message, that the new message led does not flash at all? Perhaps it does flash initially but it is turned off at a later time, so that when the user comes home, it is off. Can someone watch the message led by recording a message by calling from a mobile phone? Can someone else who has Firmware 5.072 or 5.075 confirm if they also have this problem? - Home - 04-22-2007 I phoned in on the mobile while on site a couple of times so i can confirm that the LED does NOt light up when phoning in remotely - as i said the LED did work when you left a message from the keypad. I did not try phoning in with the security system armed! - ixalon - 08-24-2007 Hi there, I\'m having a problem with the KP04 keypad on an Ultra 2 comfort. When external messages are left, the Msg LED does not show. Pressing \"#\" says \"No messages\". When I leave a memo via the keypad, the LED is lit and pressing \"#\" tells me who has messages. When signing in, I hear both answering machine and memo messages which have been left. I\'ve tested leaving an answering machine message from a mobile, and the keypad definitely never shows any sign of a message being left. We have 2 users set up - however I\'ve tested this with only 1 un-named user and it still doesn\'t work. System control number (from Engineer 7,4,3): week 5 75 26 2 Any idea if this can be fixed at my end or will it require a firmware upgrade? Best regards, Chris - slychiu - 08-24-2007 We only recently identified the cause of this problem. It only occurs in the UK (on some telephone lines?) due to BT giving a Dial Tone when the caller hangs up after leaving a message. In other countries, a BUSY tone is heard by the called party, ie the Comfort answering machine. The unexpected dial tone caused Comfort to end the recording without the proper termination, hence the MSG led was not turned on even though the message was recorded. This was difficult to identify as we could not reproduce the problem in our own testing, and we had to make a trip to the UK to an actual customer site to see this happening and thus figure out what was causing the problem. We have fixed this in firmware and it has tested on site (thanks to palmlodge) We are making this new firmware available to all those who have this problem. Please email us at upgrade@cytech.biz with the following details Name Address Telephone Firmware version - see label on Comfort U1 IC Which company you bought your Comfort from regards Cytech |
