clearing alarms via IP - Printable Version
+---- Thread: clearing alarms via IP (/thread-933.html)
Pages: 1 2
- ident - 06-16-2011
I undesstand what you are trying yo do now
The principle is that the KD commands to a UCM means the UCM itself is the \"keypad\" This will not make another keypad talk, just like you do not sign in on one keypad and get the voice menu from another keypad
However you can achieve the same effect by using the AUD01 audio plug in which goes on top of the new UCM. The AUD has a voice and mic jack. You can connect the Voice to an external amp and speaker to output the voice, and the MIC to an external microphone
When you press keys on the touchscreen which causes voice on the keypad, the voice can be heard on this external voice connection. You can use an inceiling or other speaker for this, and you can make the Control4 touchscreen work like a real keypad in this way
- incontrol - 06-16-2011
Ok thanks for confirming this I’ll get a ucm with audio and try this
Like I said I am not sure yiur UCM01 can accept a AUD01 or whether the old firmware can support it
