Screeching when Downloading! - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: Screeching when Downloading! (/thread-935.html) |
- palmlodge - 02-29-2008 Doing another download to Comfort - it\'s doing it again - admin - 02-29-2008 Did this just start happenning, as I am sure you have been doing many downloads? Did it start from anyspcific firmware change - admin - 02-29-2008 We will check out of we can hear the screeching sound with 5.121 - palmlodge - 02-29-2008 [user=606]admin[/user] wrote: Quote:Did this just start happenning, as I am sure you have been doing many downloads?Literally only happened today - been running latest f/w for a while and did a last download about a month ago. - garym999 - 03-02-2008 Like wise since 5.121! - Warby - 03-19-2008 Its almost like a dot matrix printer in a way, just alot louder! Have done 3 downloads today the first One didn\'t screech the last two have. I am only adding responses and haven\'t been in the panel in between. This is really starting to get annoying, Not so much for me but for the clients whose houses i am working in. Not being able to download because there is a baby asleep is a little bit annoying!!! Can we please have a update on this problem? Mark - Warby - 03-19-2008 I have just downloaded the default config and it still does it! - palmlodge - 03-19-2008 Just attempting to download a new config and it\'s doing it again. - admin - 03-19-2008 The only thing that could seem to be screeching is when there is a trouble beeping on the keypad during the download, and theere is some sound in sync with the beeping Can you see if the keypad green led is blinking and if so can you clear the trouble before downloading? - palmlodge - 03-20-2008 Im making a small change to a response and doing a full upload. No problems to report on the system before I started. Its now screeching doing the full upload. Its a sound interpretation of the Hex characters being sent. ie if there are some lines with \"FFFFFFFFFFF\" etc, then it screeches less. |
