- DavidJ - 03-03-2017 Briefly if you look at recently you should see the activation of the bell. If this works you can use it to trigger other things... - Pgordon - 03-03-2017 [user=1738]DavidJ[/user] wrote: Quote:Briefly if you look at recently you should see the activation of the bell. If this works you can use it to trigger other things...That\'s the problem... it has no events at all under recently... and I see no change on the live view either - even briefly... The ST device does not appear to be responding to a doorbell ring... - DavidJ - 03-03-2017 Sorry I can only say that\'s how mine works i assume you are using the latest published version. Also try refreshing the comfort bridge in \"things\". - mattbrain - 03-03-2017 Gosh Lots more activity in this thread - it\'s becoming difficult to track the different issues. May I request that you raise new issues as separate threads please ![]() I have a beta on a new SmartApp and some devices which can be downloaded here; please give this a go if you are struggling to discover and delete devices. It adds the ability to flush the device cache and devices which are unticked will be removed (subject to them not being used by a SmartApp). It is in beta, so YMMV. bagushandhoko, Refresh should bring them all back to life if they go offline - if they persist in being offline, please check the following:
Thanks, Matt - mattbrain - 03-03-2017 OK Further to my previous message, I\'m going to lock this thread (sorry folks). Please raise new issues in separate threads, hopefully it should make all our lives a little easier ![]() Thanks, Matt |
