Word lists - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 2.X (https://www.comfortforums.com/forum-67.html) +---- Thread: Word lists (/thread-1132.html) |
- Vicente - 08-06-2008 The answer to your questio is no. When I open the file you sent spantest.ccl, comfigurator open with template Comfort I PRO and with the spanish word, but if you check the wod list are still: - Standard residential - Chinese residential - UK residential - Pagewatch - Australian residential If I open an existing file the system change to a Standard residential. - Vicente - 08-06-2008 Mr Chiu: I tried a very simple thing, just edit the file I\'m using and just change \"Standard Residential\" to \"Comfort I Pro\". This solution works but when I tranfer to the system I got a message that you\'ll see in the attached doc. As you can see, I\'m using a diferent spanish language than you have. I used to work with Andrew, and I sold more than 50 comfort in Spain (in 2004) before you start with the new Spanish distributor, we translate the english words to Spanish and perhaps you change something in the original words. Waiting your comments. Vicente - slychiu - 08-06-2008 Vicente I will contact you by email to sort out your vocabulary problems |
