Comfigurator 2.9.9 - 2.9.11 Beta - Printable Version
+---- Thread: Comfigurator 2.9.9 - 2.9.11 Beta (/thread-1304.html)
Pages: 1 2 3 4 5
- admin - 01-29-2009
We found that there is a bug in UCM firmware which causes s? not to have a reply
This will be fixed in the next UCM firmware
Thanks for the feedback
Quote:Should the s?nn work at the moment?
Is the temp sensor on SCS1  then s?08
If so what response should I expect back as I dont think it does anything right now (but difficult to tell as incoming messages on the bus might be masking it)
- juwi_uk - 01-29-2009
Hi Chiu
Tested out 2.9.11 the other night and Smartfit commands look to be ok now.
Still:
* Problem I reported the other day about sunrise sunset wizard (the Algiers problem).
* Getparametervalue does convert on opening CCL file but that\'s easy to fix unless you\'ve got loads to do.
* Sensor value can now be toggled in homecontrol but always says \"unknown\"; presumably the UCM firmware issue you just mentioned.
* In home control and response wizard you select sensor by name but response source window shows as the number which seems different to other response actions which still show the name.
Looking good otherwise though.
J
- wexfordman - 01-29-2009
Thanks,
Never checkend the firmware of the cwmo2, which is what i am using, is it possible to upgrade the cwmo2 firmware ?
Regards,
Eamon
The CWM02 firmware should be 5.128. It is possible to upgrade in future but this is the current version
The problem with not being able to transfer the program is with the beta version of Comfigurator, not the CWM, and it will be fixed in the next version so dont worry
Do you mean that the problem with sunrise/sunset still exists?
I believe it has been fixed
You may be opening an old file which was saved with the problem
If you start  a new file and save it and open it again, you should find that the city is saved with the file
Sorry about that.  You are right.
Would be nice to be able to type a custom Country and City etc as in my case I\'m putting in my longitude and lattitude manually for my city so would be nice to be able to name it.
These settings arent in an XML file of something are they ie so I can add my setting and name it via this method?
You can do that by editing the cities.csv file in the config folder
[user=606]admin[/user] wrote:
Quote:The CWM02 firmware should be 5.128. It is possible to upgrade in future but this is the current version
Thanks again. I just got my comfort II, and am swapping it out from an older comfort I so a bit rusty (early 9 years ago since I put the origional in!!).
Using the existing comfigurator, I dont see options to do the following for eaxample:-
if flag sitting room is set AND security status = day mode,
I think it needs to be done with multiple if statements with the existing comfigurator. Would you recommend I hold off on building a fully functional config file until the beta issue is sorted ?
Regards,
EAMON
If you want to use AND statements it is much much  easier with the new version, so it is best that you wait a while
You can start programming though, and you can convert to ccl and download (now called WRITE to Comfort) if you need
Thanks again,
So use current release of comfigurator and save as ccl to download, or use beta version, save as ccl and download using current release ?
