Comfort and Homeeasy - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Miscellaneous Interfaces (https://www.comfortforums.com/forum-47.html) +--- Thread: Comfort and Homeeasy (/thread-1765.html) |
- palmlodge - 03-04-2011 Is this because of rfxcom\'s new NDA on the protocol ? - slychiu - 03-04-2011 No problem with that, we have signed an NDA - palmlodge - 04-12-2011 Any update please ? Been a few months - are we able to buy the RFXCom and connect to a Universal UCM today ? - ident - 04-13-2011 Not today We have the Universal UCM working with RFXcom to control Homeasy but we are not ready to release yet - palmlodge - 05-12-2011 Any news please ? What challenges do you have if there\'s a hold up ? I now believe Cytech should have a Twitter account ;-) - slychiu - 05-13-2011 The main challenge is testing to make sure it works well enough to release - palmlodge - 05-13-2011 Field testing with customers, perhaps ? - biccies - 01-18-2013 Sorry for dragging this thread out from the depths of time. I\'ve been looking at the comfort system, and probably will go with it either way. I\'ve still not committed to the HA protocol I wish to use (I was going to go with z-wave). But having the ability to interface with rfxcom would open many doors. Is it likely that there will be some integration into the comfort system? - palmlodge - 01-18-2013 I\'ve been using Comfort RFXCom to HomeEasy type modules for some time. It\'s 95% there. What we\'re missing is support for the ACKs from the RFXCom module which makes is less than 100% reliable. No idea if Cytech are going to put any effort into resolving that tho. - ident - 01-21-2013 rfxcom have firmware for XPL which allows send and receive to the same port, but using UDP instead of TCP/IP The documentation for XPL can be downloaded from http://www.rfxcom.com/documents/RFXCOM%20implementation%20xPL.pdf You can flash the rfxcom firmware following the instructions We will come up with some intructions on configuring Universal UCM for UDP for sending commands to this device |
