Siren/Bellbox Connections to Comfort - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html) +--- Thread: Siren/Bellbox Connections to Comfort (/thread-2288.html) |
- ident - 03-18-2013 [user=4834]sppooky[/user] wrote: Quote:TR- negative tamper returnTR- negative tamper return - to TAMP V- negative supply - to COM ST- negative strobe trigger - to STR- V+ positive supply - to +12V S- negative sounder trigger - to SRN- - sppooky - 03-30-2013 Hi thanks for the reply. When I opened the bell box the connections are slightly different to what was stated in the instructions. The 5 wired connections are ST- R- SW- V+ V- Does R- go into tamp? What about SW-? Cheers - ident - 03-31-2013 There must be some documentation to explain these labels otherwise you will have to do it by trial and error for R- and SW- for tamper and siren -ve - wiredhome - 04-04-2013 i would think st- strobe trigger r- tamper return sw- siren trigger or tamper switch neg ve+ pos bell hold ve- neg bell hold off scan and post the instructions from the sirenor a photo of the connections and i can decipher them for you - steefdebruijn - 07-16-2013 Hi Same question, different hardware. The aritech as271 has the following connections:
How to connect to comfort? I did the following, but cannot test yet because my house is not finished :-)
But maybe the siren is a normal speaker and i should use the spk- and 12vf terminals... Steef - ident - 07-17-2013 Your connection seem correct Do not connect to the SPK terminals of Comfort. External bellboxes are not that way - ninotorres - 09-14-2013 Anyone has experience in connecting an EDS AS240 siren to Cytech? The only documentation I have is the one in the following URL: http://www.unitech.com.tr/upload/KLAVUZ/EN/AS240_Eng.pdf Attached is a picture of the only connections I can see in the SIren. My bet is: PCM SRN+ ---> SIREN \"+\" PCM SRN- ---> SIREN \"-\" PCM STR- ---> SIREN \"B\" Comfigurator settings are at default on the siren related settings. I don\'t get any sound on Siren. I can\'t even see the status leds in the Siren blinking. The siren has a battery module that I can be sure if it is only for backup or for normal operations. Is it possible that the bateries are depleted? Thanks, Nino - ident - 09-15-2013 The photo does not match the connections on the manual Photo has Tamp , + - B Manual is SAB, + - S You should ask them for the correct manual The + and - should be from Comfort12V and COM, NOT SRN+ and - Assuming the B terminal is siren trigger, this should be connected to SRN- |
