Comfort Ultra Firmware 6.020 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Firmware History (https://www.comfortforums.com/forum-60.html) +---- Forum: Comfort Firmware (https://www.comfortforums.com/forum-79.html) +---- Thread: Comfort Ultra Firmware 6.020 (/thread-2815.html) |
- ident - 07-25-2012 can you send your cclx file to suport@cytech.biz for checking - cgiltrow - 08-09-2012 Hi, cclx file sent to support@cytech.bix. Many thanks, Clinton. - ident - 08-11-2012 Hi Clinton Thanks for the file and feedback we have found the cause of the problem, which is a bug from 5.220 or 2 years ago If you assign an output to the Security > Status > armed or Home leds then this will cause the behaviour of armed/Home leds not showing the correct status This will be fixed in the next firmware To work around for the time being, remove the outputs assignment from Security > Status |
