Comfigurator 3.6.4 - Printable Version
+---- Thread: Comfigurator 3.6.4 (/thread-3261.html)
Pages: 1 2 3
- ident - 02-16-2013
That is correct, you cannot open the window again until the upgrade is finished
However the upgrade is still working in the background, and it will finish if you leave it.
- juwi_uk - 02-16-2013
I left it for a while but it never finished.
Unless Comfigurator hangs, then either the upgrade completes or there is an error, in both cases the upgrade process ends and you should be able to switch back to Comfigurator.
Does this happen every time you upgrade fiirmware?
while comfigurator is minimised you can tell if the upgrade is still going on by loooking at the D11/D12 leds on the UCM. They keep flashing constantly and stop after the upgrade ends
- Ian - 05-30-2013
I am still having issues with the scan function. I have added modules manually as suggested but still get the error message Comfort or UCM firmware does not support scan function. Can I turn scanning off?
- ident - 05-31-2013
Have you upgraded Comfigurator to the latest 3.6.8?
You should upgrade your UCM and Comfort firmware to the latest version
Comfigurator 3.6.8 allows you to upgrade from the server by right cllicking on the module and selecting check for updates
Scanning is a very important part of Comfigurator and cannot be disabled
After upgrading firmware and Comfigurator let us know if there are any modules which cannot be scanned and show a  screenshot
But please start a new topic as this topic is to do with Comfigurator 3.6.4 only, and wil be closed
