Features in Upcoming Comfigurator 3.7 - Printable Version
+---- Thread: Features in Upcoming Comfigurator 3.7 (/thread-3453.html)
Pages: 1 2 3
- slychiu - 09-29-2013
Please note a new bug confirmed below
Selective Write does not select Control Menu when Responses change which are assigned to the Control Menu. To workaround, please use Full WRITE. This may be a bug from older versions and not new to 3.7
- ident - 10-03-2013
The next version 3.7.6 is expected to be the released version after final tests. This mainly fixes bugs from earlier versions
Bugs fixed
  1. Reading from Comfort  caused an exception if a write to Comfort has not been done
  2. Blinds function has been fixed
  3. Thermostat function has been fixed
  4. Action \"If Last Security Mode\" only could \"Security Off\"
  5. GSM4 - Get status interrupts  caused Firmware Upgrade for GSM4  to fail repeatedly.
  6. Links to manuals were not complete in each Module
  7. Selective Write did not select Control Menu when Responses change which are assigned to the Control Menu.
New Features
  1. Edit > Autogenerate Names will also autogenerate Response names from Actions codes similar to Read from Comfort with the \"autogenerate\" option.
  2. Action 189 for blinds function has been implemented
  3. Zwave configurator major improvements to (described later)
  4. GSM4 Configurator has been implemented (described later)
  5. Heatmiser Configurator has been implemented (described later)
A full description of the changes for 3.7.6 from the last version 3.6.8 shall be given in a new topic
- Home - 10-03-2013
juwi - the pictures are obviously a screen shot but how do you get the torn edge effect?
- Home - 10-03-2013
Another thing !
We have been to attend several old C1 installs and tried to extract the program file using Comfig 3 - - - - no luck
We have had to go back to the old 2.2.3 extract the file and then upgrade and then re-load .cclx using C3
- juwi_uk - 10-03-2013
Snagit
- slychiu - 10-03-2013
Send us the ccl files of the C1 systems that you read from Comfort so we can try to check with C2
