New Features for UCM/ETH03 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Thread: New Features for UCM/ETH03 (/thread-3796.html) |
- cc_uk - 08-06-2014 Suggest check you have a DNS server IP address defined in your IP setup on the ETH 03 module - Pharris14 - 08-07-2014 I have my router address as the DNS, is this correct? - ident - 08-07-2014 We have tested your email server, and it has no problem with emails The Gateway should normally be your router IP address The DNS is normally your router IP address, but not necessarily so, depending on your network. Have you tried using your ISP DNS setting? - ident - 08-07-2014 Also please log out from Comfigurator before testing the email function - Pharris14 - 08-07-2014 I have tried both my router as DNS and also my broadband provider DNS\'s but this still doesn\'t work. I have logged out of Comfigurator before testing. Am I correct in that if I disconnect the AC to generate an event that this should initiate an email being sent? Are there any diagnostics which I could perform? I also have Comfort Client installed on my PC and this can send emails OK (I don\'t know if this has any relevance) - ident - 08-07-2014 Try other alarms eg Dial Test by pressing F3 and 3 on the keypad Can you send a screenshot of your email setup on CS Manager? - Pharris14 - 08-07-2014 I have no phone connected at present, I have tried intruder alarm and still no email. I feel that I have missed something fundamental Screenshot attached. - Pharris14 - 08-07-2014 I found the problem, I didn\'t realise that you had to re-enter the authentication password every time you made any changes. I mirrored the port and Wiresharked Comfort, the SMPT server failed authorisation. Thanks to all - juwi_uk - 08-07-2014 Chaps Surely it should remember the password but show it as ***** ie masked. Only when you click in the password field should it then clear imho. Julian - ident - 08-08-2014 Hmm, I assumed the email server did not require authentication |
