Comfort 2nd Generation Android App Version 1.4 - Printable Version
+--- Thread: Comfort 2nd Generation Android App Version 1.4 (/thread-4197.html)
Pages: 1 2 3 4
- wexfordman - 05-19-2015
okay, reconfigured the control menu as you outlined, and icons etc all appear to be working and editable now.
Had the app crash few times, and seems a little slow, but will see how it is overall one I use it a it more.
Thanks a million, looks great :-)
- wexfordman - 05-20-2015
Just an update on how things are working now that the icons arc are working.
I find it crashes quite a lot or Hangs.
I have one Veonus dimming. module which I set up the slider to work with. It freezes or crashes when it is used. I suspect this may be my understanding of how to implement it being wrong though.
- slychiu - 05-20-2015
Your firmware is ULT 7.065, can you upgrade to 7.072 (Beta) which fixes some problem with the slider
- wexfordman - 05-21-2015
[user=1]slychiu[/user] wrote:
Quote:Your firmware is ULT 7.065, can you upgrade to 7.072 (Beta) which fixes some problem with the slider
I did that. The slider does not work , but again that may be more to do with my programming.
The app itself though seems very buggy, pauses, freezes or just very slow to respond to commands.
- slychiu - 05-21-2015
Is there a certain point that the app has problems?
can you try uninstallling and re-installing again, as that worked for Julian
If you dont touch the slider do you have the problem?
- wexfordman - 05-22-2015
Quote:If you dont touch the slider do you have the problem?
Nope, without even going near the slider, the app seems very unresponsive, and takes a long time to react to a keypush to turn on a light, sometimes taking several attempts.
I deleted and re-installed with no improvement.
The gen 1 app is much faster in comparison.
Regards,EAmon
- slychiu - 05-22-2015
How about the Gen2 app v1.3 before this 1.4 update? Did you encounter the same problem?
- Ingo - 05-22-2015
I also have an issue with the new app. When I start the app the Login button is greyed out. I have to switch from Local to Remote and back to Local again to have the button become available.
Same question, do you mean the Gen2 1.4 app compared to 1.3 or the G2 app compared to the 1st gen app?
