SMS Trouble after power failure - Printable Version
+--- Forum: GSM Module (https://www.comfortforums.com/forum-48.html)
+--- Thread: SMS Trouble after power failure (/thread-4900.html)
Pages: 1 2 3 4
- caravanboy - 01-07-2020
I think I did do that in the past but I will do it again. I think I only pulled power to my main panel though (which has the GSM module) and not the separate supply to my SEP panel. You could imagine some quirky behaviour if both lose power, or something like that. I will try and also disconnect the network cable from the ETH module as when I lose power that would also effectively lose it\'s connection, just in case that makes any difference. I\'ll report back in a few days...
- slychiu - 01-08-2020
Quote:I will try and also disconnect the network cable from the ETH module as when I lose power that would also effectively lose it\'s connection, just in case that makes any difference.
Do not disconnect the ETH03 as that would mean we would not be able to monitor the GSM status
The battery shpuld powere up the Comfort and UCM modules, they should not lose power
- caravanboy - 01-08-2020
yes, okay, good point. I just meant as an optional test (after I\'ve checked signal levels etc) to see if that\'s the trigger for making the GSM module start to fail
- caravanboy - 01-20-2020
Hi Slychiu,
I haven\'t got around to doing a controlled power failure test but I was at home today when we had a 45 min power outage so I did some checks during that power outage:
During the full power failure, my network switch and wifi were on UPS now so I eventually (*see below) got Comfigurator on my laptop to show the GSM4 UCM GSM network signal status. It showed \"Good - 3\" as the network strength but I had NOT received a power fail SMS text message.
When the AC power returned after ~45 mins, a few minutes later I did then receive a Power restore SMS message. Also, when the AC was restored I then immediately checked the signal strength again and it showed \"Fair - 2\" and texts are working normally. I never miss one under normal circumstances.
So, I\'d say this seems to show that the fault is very likely with Comfort. I can still do a controlled test power failure (i.e. Comfort main panel only) if needed, but the fact that the GSM module claimed to have a good signal strength does point a Comfort bug somewhere.
* I think there is a minor Comfigurator bug/quirk - if you launch and open the config, navigate to the relevant GSM4 Module and click \"Get Status\", it asks you for the PIN to login, but then does not immediately show the status. Trying again now I think it puts you on to a different page and you have to navigate back to that page, but maybe I did not notice that earlier during the power failure.
Also, when I was in power fail situation, the \"GSM Network Strength...\" message appeared in red for a couple of seconds and was then replaced by \"Normal/No error\" in black and no mater how long I waited the signal strength message didn\'t reappear without me navigating away from the module and back again.  Now I\'m in AC-okay mode, it still does mostly stay on \"Normal/No error\" but does regularly (every 30 seconds or more?) switch to the signal status message, but still only for a couple of seconds. Not
- slychiu - 01-21-2020
We have bot been able to find any problem with diak out during power failure
Please upgrade to GSM4 7.128 Beta firmware which has some improvements in operation which may or may not have an effect on your probelmsfrom https://www.cytech.biz/product_details.php?item_id=227
- caravanboy - 01-21-2020
Ok, thanks, I\'ll download and try that over the next week or so and let you know.
Before installing the new firmware, I will still try and do the manual controlled power failures (of my Comfort main panel, and SEM01 panel) as they are on different circuits within the house, just so I have that info to help with the diagnosis too
- caravanboy - 01-27-2020
I did some manual power failure tests as follows but all worked as expected:
1) Power fail on main panel - official Comfort SMS received OK, voice call OK, test SMS worked during power failure, AC Restore SMS worked ok.
2) Power fail Slave panel only - no Comfort SMS (as expected), test SMS worked during power failure.
3) Power fail Slave, then power fail main panel (approx. 2 mins later) - official Comfort SMS received OK, voice call OK, test SMS worked during power failure, AC Restore SMS worked okay.
So, I just need to remember how to upgrade firmware now as I\'ve not done it for a couple of years. Comfigurator only seems to offer me a \"by cable\" option. Hmm
I guess I can then just have the latest beta GSM4 firmware installed and wait for the next full power failure.  Perhaps the issue is caused only when the main and slave panels fail at exactly the same moment?
- slychiu - 01-28-2020
You donthave to use the firmware upgradingt cable if your UCM and Comfort are version 6 and above
see http://www.comfortforums.com/forum92/3400.html for instructions
- caravanboy - 01-28-2020
Thanks. GSM4 successfully updated to beta 7.128 firmware. Basic GSM tests appear okay. Will await next full AC failure (sadly shouldn\'t be too long given recent power outages in our area) and will report back after that
- caravanboy - 05-04-2021
Hi Slychiu,
As mentioned above, I upgraded UCM/GSM4 to 7.128 a while ago but that did not show any noticeable improvement on this behaviour – the AC Fail/Restore SMS messages rarely arrived promptly after a power failure, although I did not have as many outages as usual in the last year so I didn’t get back to looking into this.
About a month ago I upgraded my system to the most recent firmware for all components (Comfort, Slave and UCM/GSM4 etc). Yesterday was the first power outage I’ve had since being on the latest firmware but I’m sure there’s still something not right…
We had a power failure at 8:20am for around 10 seconds. I acknowledged this from the keypad (to stop the warning beeps) and then also received a call to my mobile which I acknowledged. I did not receive any SMS messages until 7 minutes later and their contents showed they were generated at  8:27:54 and 8:28:04 for the “AC Fail” and “AC Restore” respectively.   By the way, it is nice to see that the newer firmware has added the seconds in to the message times.
I checked that Comfort’s time is still accurate so those messages were only generated by Comfort about 7 minutes after the power outage.
Relevant items from the event log still show some sort of initial SMS Trouble and then an SMS Restore (8:21am) but then repeated failures to send after the SMS Restore, before the AC Fail and AC Restore messages were eventually sent to both my phone and my wife’s. This is very similar to the behaviour we saw back in April 2019 (on this thread) when the failures continued after the SMS Restore. You can see from the other tests I did a while ago (Jan 2020) that when the power has failed Comfort still show the signal strength of the cell is okay.
Do you have any further suggestions or ideas of how I can investigate this further?
Event log shows this (also nice to see that the misleading/confusing Dial Failure error number has been replaced with a zero):
05/03 08:20 AC Fail 1
05/03 08:20 AC Restore 1
05/03 08:21 SMS Trouble ID # UCM 2
05/03 08:21 Sign in - User # 2
05/03 08:21 Dial Number # 3
05/03 08:21 SMS Restore ID # UCM 2
05/03 08:21 Remote Signin - User # 2
05/03 08:22 Dial Number # 1
05/03 08:22 SMS Dial Failure # 0
05/03 08:22 Dial Number # 2
05/03 08:23 SMS Dial Failure # 0
05/03 08:23 Dial Number # 1
05/03 08:24 Dial Number # 2
05/03 08:24 SMS Dial Failure # 0
05/03 08:24 Dial Number # 1
05/03 08:25 SMS Dial Failure # 0
05/03 08:25 Dial Number # 2
05/03 08:26 Dial Number # 1
05/03 08:26 SMS Dial Failure # 0
05/03 08:26 Dial Number # 2
05/03 08:27 SMS Dial Failure # 0
05/03 08:27 Dial Number # 1
05/03 08:27 Remote Signin - User # SMS Acknowledge
05/03 08:27 Dial Number # 2
05/03 08:28 Remote Signin - User # SMS Acknowledge
05/03 08:28 Dial Number # 2
