Comments on iphone app V1.40 to 1.42 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html) +---- Forum: Comfort iPhone App (1st generation) (https://www.comfortforums.com/forum-96.html) +---- Thread: Comments on iphone app V1.40 to 1.42 (/thread-2373.html) |
- gaynorc - 08-10-2011 I understand the DNS bit. Just to understand more about this problem, I wasnt talking about the cameras, I was talking about the main comfort IP address for internet access. As I said, for the app I use the hostname without the http:// prefix, its a simple hostname like xxxxx.eu I connect no problem from the internet to comfort every time. - ident - 08-10-2011 Thats strange I could not get dyndns to work with the same method - bs85 - 08-10-2011 I use dyndns with hostname xxxx.ath.cx and it won\'t connect Checked router logs and there is nothing when using the hostname - bs85 - 08-11-2011 Just tried to connect using a remote wifi connection and using hostname is working fine. So the problem i have is using a cellular connection and hostname. - ident - 08-12-2011 What do you mean? If you are using wifi to connect remotely the hostname works in the Internet field. But if you are connected by 3G and not wifi then you cannot connect? - bs85 - 08-12-2011 [user=86]ident[/user] wrote: Quote:What do you mean? Yes that is correct hostname and remote wifi working hostname and 3g not working - ident - 08-12-2011 That does not work for me Has anyone else tried this? - wexfordman - 08-12-2011 iPhone app appeared in the app store as requiring an update today, and I updated it! Now it\'s shutting down when I go ibot hone control menu ( second level down) Anyone else seeing this ? - ident - 08-13-2011 Yes I see the same problem The change in the update was only in the setup fields We will get this fixed and load a new upgrade Please do not upgrade to 1.41 !! - bs85 - 09-14-2011 Just updated the app on my iPhone and now hostname is working on 3G. Thanks |
