Comfigurator 2.9.9 - 2.9.11 Beta - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Comfigurator 2.9.9 - 2.9.11 Beta (/thread-1304.html) |
- juwi_uk - 02-01-2009 Thanks very much as I though i was going mad. My wife was getting very upset with me and eventually set the volume on all the keypads to zero as it kept waking her up ![]() As asked by others it would be good if we can get an \"Announce Sensor\" in the future so would need these workarounds. Thanks for your help. I\'ll try this now. Julian - juwi_uk - 02-01-2009 If you rename a counter then the responses where that counter is used automatically and correctly rename as well. The counter name is NOT renamed though in the reference used in Feedback Name in the Contorl Menu (might do it elsewhere too). Is this a bug or feature? - admin - 02-01-2009 You have done it again., That is a bug which should be fixed in the next (not 2.9.12 though which is being tested) - admin - 02-02-2009 We could not duplicate this in 2.1.12 Please test this in 2.1.12 which has just been released https://www.cytech.biz/Default.aspx?cmd=sQ0OYE9X66w%2b0P%2bAcFsmAI3j73Rwtfrj&fileid=203&dcid=4&pageindex= - admin - 02-02-2009 The new version 2.9.12 has been released. A new topic has been started http://www.comfortforums.com/forum20/1332.html and this one is now closed - juwi_uk - 02-02-2009 Nope it still does it in 2.9.12. Have sent an AVI of the issue in action to support@cytech.biz J - admin - 02-02-2009 We cannot duplicate this so far, will do more testing - juwi_uk - 02-02-2009 OK thanks. I\'m on Vista x64 Ultimate by the way. J - tech07 - 02-03-2009 We managed to see this happening If the drop down word list is open and an event occurs (like a zone activation) in the Monitor I/O window (opened when the Check status box is checked) then the Phrase words label goes grey and the list floats However we find that the word list can still be selected and there is no exception It may be a specific event which is causing the exception Can you repeat the situation and if the exception occurs copy the Monitor I/O window - there is a Copy to Clipboard button |
