iPhone iOS5 problems using 1.4.4 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html) +---- Forum: Comfort iPhone App (1st generation) (https://www.comfortforums.com/forum-96.html) +---- Thread: iPhone iOS5 problems using 1.4.4 (/thread-2520.html) |
- gaynorc - 10-25-2011 [user=86]ident[/user] wrote: Quote:When you get the Connecting.. and data error message, can you use DS Manager and see if there is a connection symbol on the UCM/Ethernet as seen in the screenshot with the double arrow? This means that there is a connection active and it will prevent a new connection from being madeIdent, NB device is 192.169.0.98 When I first opened DS Manager with the app connected, I saw broken red arrows in each direction with the explanation \"serial-to-Ethernet buffer overflow\". I disconnected (closed the app), the red arrows disappeared. I opened the app, the red arrows reappeared. Screen print attached. I have been unable to reproduce this yet. I therefore rebooted the ETH02 to get a fresh start. I start with connection closed/device idle on DS Manager. No arrows. Then I try to connect firstly with WiFi. Normal connection established (blue arrows in each direction). App works okay. I close completely the app. I wait. Then I open the app in 3G. I DO NOT select a system. Yet on DS Manager I get blue arrows in each direction. The Device is connected. I select a system, and I get \"data error\" on 3G, on DS Manager blue arrows in each direction. I wait, and try again, I connect, then \"data error\", then no blue lines on DS Manager. I try again, this time I connect okay. Again on DS Manager blue lines in both directions. - gaynorc - 10-25-2011 Update: After some time connected via wifi with no problems, a connection error happened. Reconnected. Thereafter the DS Manager shows the connection with broken red arrows in each direction with the explanation \"serial-to-Ethernet buffer overflow\". In DS Manager is this just a record of the last error, or an ongoing error? - ident - 10-26-2011 Please see possible fix in here http://www.comfortforums.com/forum96/2540.html This topic will be closed, as it is now more than 3 pages. Any comments please continue there |
