AC Fail icon remains on KT01 even after power restored - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: KT01 Touchscreen Keypad (OBSOLETE) (https://www.comfortforums.com/forum-46.html) +--- Thread: AC Fail icon remains on KT01 even after power restored (/thread-1456.html) |
- admin - 05-05-2009 This is a problem where the AC Fail icon on the KT01 remains on when there is no AC Failure on Comfort This happens when there has been an AC Failure on Comfort followed by removal of the battery due to system power down, OR the KT01 has been switched off. When the KT01 loses power and power is restored, it remembers the last state, hence the AC Fail button remains on. However if Comfort is powered on, it will not send the AC Fail restored as there was no AC Failure after power on. Hence the KT012 AC fail state remains on To correct this, remove AC with battery connected until there is AC Fail detected by Comfort. Then switch on AC again. The AC fail state will turn off immediately To prevent this in future, remove battery before switching of AC |
