Dynalite UCM Bug - Printable Version
+---- Thread: Dynalite UCM Bug (/thread-1511.html)
- Warby - 06-09-2009
I have just noticed a very concerning bug in V3.0.1. I am using a UCM dynalite which has been working for 2 years now. When i open a response that is using a Linear preset command i.e Dynalite LinearPreset 2 17 3 0 255, every time a reopen it it adds 1 to the preset number. the above response should be Dynalite LinearPreset 2 17 1 0 255. it is doing this to commands from v2.3 and also if a add a new command to the response. I will look thru some of the other dynalite commands when i have time.
I have tested this a little bit and in the attached program there are 2 dynalite responses that are buggy, DT2 and DT3. DT2 adds 1 to the preset value whenever the response is opened and i think when it is downloaded (offline so can\'t test). DT3 won\'t open without errors.
- ident - 06-10-2009
Warby
Thanks for the report
The Issue with the Linear Preset being incremented was found and has been fixed for the new version, see Known issues in http://www.comfortforums.com/forum20/1446.html
We are looking at the Exception caused by DT3
