Comfigurator 3 problems - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Comfigurator 3 problems (/thread-1646.html) |
- technik23 - 10-26-2009 I\'m having problems with IR codes. When I learn a new code it doesn\'t appear in the drop down list when I want to use it. Only the preset codes appear. It is in the IR folder. I\'ve checked to make sure I\'m referencing the correct file. Also importing an IR code has the same problem. I am using Comfigurator 3 on an old ccl file and it doesn\'t pick up the IR codes that I used in that application. Also I\'m getting a strange effect when I use execute resonse command in that it seems to execute it 3 times! Thanks Bernard - admin - 10-26-2009 Bernard Can you send me the IFR file so we can try it? Are you using Comfig 3.1.3? if you use it on a ccl file, you will not pick up the ir code because ccl files do not contain the ir code- that was an innovation in Comfigurator 3 How do you know that the response is executed 3 times? Thaqt should not be possibl;e |
