UCM/Velbus - Learn function - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Velbus (https://www.comfortforums.com/forum-88.html) +--- Thread: UCM/Velbus - Learn function (/thread-1813.html) |
- segurant - 04-12-2010 Hi, Is it possible to add more Velbus modules to the system and then use the learn function without the previous associated counters be erased? When we make the learn function with the modules having the counters associated that function erase all the associated counters to that modules. Thank you - admin - 04-12-2010 Thanks for the suggestion. We will see if this can be implemented - admin - 04-21-2010 Segurant has also discovered that there is a limit of about 42 channels in the Velbus list. Once it exceeds that, there is an EEPROM Read error. This is due to a bug in Comfigurator 3.1.9 which wil be fixed in the next release - ident - 10-09-2010 Velbus 3.1.9 allows 512 Velbus Channels to be scanned in the Learn Mode. Use Comfigurator 3.2.3 to support this function |
