Vmb4ry directly connected push buttons status - Printable Version
+--- Forum: Velbus (https://www.comfortforums.com/forum-88.html)
+--- Thread: Vmb4ry directly connected push buttons status (/thread-2369.html)
- wexfordman - 07-25-2011
Am about to get my first few velbus modules and my first purchase is to be a vmb4ry which I intend to use to replace some ad10 modules!!
I plan to use my existing clipsal momentary switches from my x10 setup to connect directly to the velbus module pb inputs, but just wanted to be sure that doing it this way will still ensure status update to comfort when the lights are activated by this push button input ?
Hope this makes sense, I just want to be sure before going ahead!
Eamon
- ident - 07-26-2011
The status update can be done by the Velbus relay module when it changes state.
You dont need to get the status update from the PB module.
You can also use the pushbutom module to send a comand to Comfort to activate a Response
