Clipsal Premise Gateway - Printable Version
+--- Forum: Miscellaneous Interfaces (https://www.comfortforums.com/forum-47.html)
+--- Thread: Clipsal Premise Gateway (/thread-259.html)
- slychiu - 10-29-2006
The Clipsal Premise Gateway can be interfaced to Comfort. This requires a UCM01 with RS232 interface.
From the Clipsal Website
[color=\"#6d6e71\"][color=\"black\"][color=\"dimgray\"]The Clipsal PremiseGateway is the solution for users to access control systems over the Internet, whilst providing broadband sharing and security services for devices on home or office LANs.[/color][/color][/color]
The Clipsal PremiseGateway acts as both a router to enable internal users to share an Internet connection, and as a secure gateway allowing authorized users to connect to control systems such as C-Bus, EZinstall, Clipsal MinderPRO, CentralAXS or other systems such as video servers and web-servers. All of these services are provided in a state of the art security and firewall framework. End users can access their control, security, CCTV and automation systems and LAN remotely, secure in the knowledge that they are doing so in a secure manner with industrial grade certification, authentication and encryption technology.[/color][/color][/color]
[color=\"#6d6e71\"][color=\"black\"][color=\"dimgray\"]When used in conjunction with the Clipsal Portal, the Clipsal PremiseGateway enables users to connect to remote systems using a standard low cost DSL connection - this avoids the requirement for expensive fixed IP addresses. The Clipsal PremiseGateway currently supports Clipsal control system products for lighting, power, access control, CCTV and automation applications. Subsequent releases of the Clipsal PremiseGateway will support a range of new Clipsal products and services as well as a wide range 3rd party products, protocols and services.
An Application Note is available on the Cytech website http:/www.cytech.biz/manuals.html
Premise Gateway is sold and supported through the CIS Malaysia office.
- Nigel - 09-28-2008
I\'m building a house and saw the specifiaction for this device and thought it was ideal for integration / Internet control of a C-Bus / Comfort solution. Where can this item be purchased in the UK??
- slychiu - 09-28-2008
There is a new version of the Premise Gateway which has not been released anywhere yet.  Check with your C-Bus supplier or Schneider UK for news
