Comms Issues - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: UCM Problems (https://www.comfortforums.com/forum-73.html) +---- Thread: Comms Issues (/thread-2596.html) Pages:
1
- ident - 11-21-2011 Hi Can you give me the serial number on the UCM and the ETH module. It sshould be P or C followed by numbers on a sticker with bar codes - ident - 11-21-2011 [user=4349]lwillerton[/user] wrote: Quote:Hi IdentYou tried to upgrade UCM6.002 to 6.008 This is good but it looks like you selected the option Upgrade by Programming Cable This is for upgrading another module with the UCM. It cannot be used for upgrading the same UCM. To upgrade a UCM using this method you need to use another UCM If you want to upgrade the UCM itself then you must use the method Upgrade by Direct connection to PC This is why you had the error The upgradiing procedure is fully described in the UCM Manual from https://www.cytech.biz/ucm_manual.html Do read the chapter on firmware upgrading before you attempt it otherwise you may end up corripting the firmware |
