RESISTORS - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html) +--- Thread: RESISTORS (/thread-2680.html) |
- radawodu1945 - 01-08-2012 I would like to know if a 12V smoke detector can be compatible with a 24V output fire alarm system, if not, can resistors be used to acheive this. Thanks for your help. - bs85 - 01-08-2012 The Comfort system is 12v so you could connect your 12v smoke detector to it. - tech07 - 01-08-2012 You should not even try to connect a 12V smoke alarm to a 24V fire alarm system There is the liability and danger if it does not work. You should use the recommended sensors for the system - pavel - 12-10-2012 The smoke detector only gives an output when it detects smoke and the output can be fed to any output system. If Iââ¬â¢m not wrong the smoke detector has 6 pins, you just need to figure out the right combination. The 24V fire alarm system has an output alarm that requires this high input voltage. I believe the output from the sensor can work with it. Only try this if you have an understanding of smoke sensor circuitry though. prototype pcb assembly - wiredhome - 12-11-2012 a 12v detector is for 12v systems so if you connect it to 24v it will blowup! |
