gsm with comfort 1 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: GSM Module (https://www.comfortforums.com/forum-48.html) +--- Thread: gsm with comfort 1 (/thread-2935.html) |
- wiredhome - 06-28-2012 Will the new GSM 3 work with Comfort 1 - ident - 06-29-2012 Comfort 1 had several PCB revisions. Only rev E6 had the 5 way audio connection for GSM so check which PCB you have. You should be able to see the 5 way white header or not on the PCB we believe the E6 should work with the GSM3 but we do not have any rev E6 PCbs around anymore to test. The last was produced 7 years ago - wiredhome - 06-29-2012 Hi Chiu the client sent me this photo it looks like the correct header what do you think? - ident - 06-29-2012 No that is the Voice Programmer connector The GSM audio is a 5 way connector - wiredhome - 06-29-2012 Oh Dear i\'ll just have to try and sell him a new system |
