UCM GSM Low Battery - Printable Version
+--- Forum: GSM Module (https://www.comfortforums.com/forum-48.html)
+--- Thread: UCM GSM Low Battery (/thread-2975.html)
- Howser - 07-20-2012
I replaced my Panel battery yesterday, and got the SMS - 07 Low Battery-001 Main as expected.
A few hours later I got the Low Battery Restore Message, but instead of 001 Main for the Panel I got the name for Zone 01.
- ident - 07-20-2012
Possible bug needs to be checked
- hendy - 07-23-2012
Howser, what is your Comfort firmware type and version?
You can get the info from Comfigurator software\'s Transfer menu >> System Information...
- Howser - 07-23-2012
[user=1490]hendy[/user] wrote:
Quote:Howser, what is your Comfort firmware type and version?
My Firmware Type is Comfort II Ultra.
Version 6.020
- hendy - 07-24-2012
I use the same firmware version to test but did not manage to get the same issue as yours.
Can you send your cclx file to support@cytech.biz so we can check?
- Howser - 07-24-2012
Project file sent.
I think I should add that in the event log, it was logged properly, it is only the SMS that had the wrong name.
Event Log
Code:
07/19 06:04 Low Battery # Comfort Controller
07/19 20:00 Low Batt Restore # Comfort Controller
Have checked your file but did not manage to get the same problem.
Can you upgrade the Comfigurator software to the latest beta 3.5.2 from https://www.cytech.biz/software.html ?
I\'m using that Comfigurator version to write your config file to my test bench.
Perhaps it is one of the bug in older Comfigurator 3.4.0 that you are currently using.
