2 PIRs on one circuit - Printable Version
+--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html)
+--- Thread: 2 PIRs on one circuit (/thread-3119.html)
- michaeljj - 10-13-2012
                    Built an extension onto the back of my house running  multicore back to the alarm panel for an additional PIR sensor. BUt there are no free zones, new PIR could be wred to an existing PIR circuit but not good though.
I had a look at the internet and I found a wiring diagram for two PIRs in one circuit. Basically, the + and - wires are in parallel and the contacts and tampers are in series. Looks logical to me.
Can anyone confirm if it is good or not. Also, could i do it myself?
- wiredhome - 10-13-2012
It will work no problem
beaware that it will make identifing which room triggered the alarm a little nmore difficult
if you can fit a plug then you should be able to do it your self.
regards
Niall
- pavel - 05-28-2013
Hello michaeljj, can you provide us the details about circuit. Which PIR are you using and how? Basis, we can provide you suggestion upon it.
