Comfigurator 3.5.6 error/termination on run - Printable Version
+---- Thread: Comfigurator 3.5.6 error/termination on run (/thread-3158.html)
- idheath - 11-15-2012
I\'ve just upgraded 3.4.4 to the latest version and I get this error when I run the app.
Code:
System.IO.DirectoryNotFoundException: Could not find a part of the path \'C:\\ProgramData\\Cytech\\Comfigurator\\ifr\'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption)
   at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
   at System.IO.Directory.GetFiles(String path, String searchPattern)
   at Comfort.IrDatabase..ctor(String ifrDirPath)
   at Comfort.Configuration.SetNonSerializedValues(SystemSettings systemSettings)
   at Comfort.Configuration.Initialize(SystemSettings systemSettings, Boolean optimizeResponses)
   at Comfort.Form1.SetNewConfiguration(Configuration newConfiguration)
   at Comfort.Form1.NewConfiguration(String filename)
   at Comfort.Form1..ctor(String filename)
   at Comfort.Program.Main(String[] arguments)
I have looked in \'C:\\ProgramData\\Cytech\\\' and there is no \'Comfigurator\' directory. (However there is a \'C:\\Program Files (x86)\\Cytech\\Comfigurator 3\\ifr\" folder).
- ident - 11-15-2012
The installation may have been corrupted
Can you uninstall and re-install Comfigurator?
Did you change the Program file path during the installation?
I didn\'t change the installation path during installation.
When i did the uninstallation, as per your instructions I noticed that I had version 3.1.9 installed in addition to the 3.4.4 version.
I\'ve uninstalled both versions 3.1.9/3.4.4 and the latest version is working now.
Thanks.
