Clarity on UCM firmware upgrade options - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +--- Thread: Clarity on UCM firmware upgrade options (/thread-3159.html) |
- idheath - 11-15-2012 I had the following: Comfort II Ultra: 6.020 UCM/ETH02 6.012 UCM/232 6.0.12 I use Comfigurator via the UCM/ETH02 and have just upgraded to the following, in the order shown (using Comfigurator): UCM/ETH02 6.024 Comfort II Ultra: 6.028 My query is how can I upgrade the UCM/232? It is not connected to a PC. I assumed I could use the \"For module connected to Comfort Bus\" option in Comfigurator but only the Controller is shown in that option. - ident - 11-16-2012 The UCM currently can only be upgraded by direct connection to a PC In a future firmware upgrade, UCMs will be upgradeable both by Bus and Direct connection For now you can just swap the ETH and RS232 submodules and upgrade the UCM by ETH02 - idheath - 11-16-2012 [user=86]ident[/user] wrote: Quote:The UCM currently can only be upgraded by direct connection to a PC Thanks for the clarification |
