- ident - 12-31-2012
The new beta version 3.6.2 can be downloaded from https://www.cytech.biz/comfigurator.html?category_id=98
Alternately if Comfigurator 3.6.0 or 3.6.1 are installed, it will automatically check for the new version each time it is run and will allow you to download the new version
Bugs Fixed
- Trying to upgrade a module from Local File with firmware shown as \"Unknown\" or less than version 6 after scanning will not be able to upgrade firmware. If the module has not been scanned, it will not be possible to upgrade the firmware.
Zwave Configurator (May require Zwave Firmware 7.xxx required)
- \"Get Status\" button will not log out after the status is obtained, Comfigurator will remain logged in to continue receiving status. Zwave 7.xxx will send status when there is any change, and not just when Get Status button is pressed.
- Colour Codes in Zwave Mapping help to identify various types of Nodes: Controllers (gray), UCM/Zwave (Blue), Virtual Node (Green), Slave Nodes (Black)
- After Virtual Node operations Comfigurator will automaticallly read EEPROM when required.
- Zwave Response Wizard supports a new Multilevel Dimming function
- If the Response sends commands to a Virtual Node a warning message pops up \"Sending Zwave commands to Virtual Nodes is not recommended as it is not guaranteed to workââ¬Â
- In Response Wizard. \"Basic Command\" renamed to \"Basic Set Command\". \"Status Request\" renamed to \"Basic get Commands\", to comply with standard Zwave terminology
- UCM/Zwave will update Comfort counters and sensors from Zwave commands even when the counter value has not changed. This allows status of Zwave devices controlled by Comfort and other Zwave nodes to be synchronised
- Help Text for Zwave commands has been improved
Velbus Configurator (may require UCM/Velbus 7.xxx)
- Added Get Status Command, also status messages will update automatically (requires Velbus 7.xxx)
- Added support in Learn Mode for new Velbus Modules VMBDMI, VMB8PBU, VMB6PBN, VMB2PBN, VMB6PBB (requires Velbus 7.xxx)
- Write and Read EEPROM times reduced
- Counter will be updated from Velbus even if the value does not change.This allows status of Velbus devices controlled by Comfort and other velbus modules to be synchronised
Known Issues
- KT03 configuration created in Comfigurator 3.6.x has an error writing to KT03. I/O Monitor shows RS4x. To workaround use Comfigurator 3.5.6 to create KT03 files
- ident - 01-02-2013
New Problem for Comfigurator 3.6.2 was found
- ident - 01-12-2013
Comfigurator 3.6.3 is available for download from https://www.cytech.biz/comfigurator.html?category_id=98
If you are running Comfigurator 3.6.0 to 3.6.2, the software itself will prompt you to download the new version from the website
New Features
- Zwave commands help text has been improved
- Bus Monitor upgraded to recognise new Rs485 commands, and improvements in display of messages with errors
Bugs Fixed
- KT03 configuration that was created using 3.6.0 to 3.6.2 could not be written to KT03 - it caused the KT03 to be reset.
- Zwave exception error fixed on send virtual Node button
Defaults
- KT03 default Portrait and Landscape templates have large buttons
Bugs
- Read from KT03 causes Exception
- Adding a new button or image on a KT03 page and changing the position may cause the element properties to be blank.
- when opening comfigurator, it checks for a new version, and if found the dialog box to upgrade Comfigurator may be hidden behind the splash screen. The splash screen may appear to be stuck. Use Alt Tab to go to the Upgrade comfigurator dialog
- Howser - 01-12-2013
[user=86]ident[/user] wrote:
Quote:Comfigurator 3.6.3 is available for download from https://www.cytech.biz/comfigurator.html?category_id=98
Comfigurator 3.6.3, is it still beta?
We have not declared it non-beta yet, but it is close and going through final testing before official release.
- ident - 01-15-2013
Bugs found in Comfigurator 3.6.3
