Wiring for wireless bell box - Printable Version
+--- Thread: Wiring for wireless bell box (/thread-3694.html)
- gjb - 01-24-2014
I am trying to connect a two-part wireless bell box (i.e. solar powered bell box + wireless transceiver).
The connections on the transceiver are as follows:
- Fault (open when in fault condition, e.g. low battery)
- Fault (as above)
- Tamper (positive return)
- Bell (negative trigger)
- Strobe (negative trigger)
- +12V
- Ground
Am I right in thinking this should be connected as follows?
Fault => Shorted to \'Ground\'
Fault => Z1
Tamper => TAMP
Bell => SRN-
Strobe => STR-
+12V => SRN+
Ground => COM
Also, what is the difference between 12V, 12VF and SRN+? Are they all permanent 12V feeds?
Thanks.
- ident - 01-24-2014
It seems  correct
Tamper + should be in series with the case tamper if you are using that.
SRN+ is also 12V but has its own resettable fuse in case of a short circuit
The 12V at the centre of each output has a 300 ma resettable fuse to protect the outputs
I cannot find 12VF
S12V is a switched 12 V which can be controlled by actions
- gjb - 01-24-2014
[user=86]ident[/user] wrote:
Quote:I cannot find 12VF
12VF is between SPK- and STR-
- ident - 01-25-2014
Sorry about missing that 12VF is the middle pin between STR- and SPK-
This also has its own resettable fuse
- rubycrew - 01-30-2014
Maybe this help you
http://www.teletechnika-system.pl/oferta/sieci-komputerowe/
- ident - 01-30-2014
That link does not work, or is extremely slow
It cant be. I click on link and everything is working
- gjb - 01-30-2014
Just to follow up on this. The wireless bell box is now installed, and the above wiring worked perfectly.
Thanks once again for your help ident Smile
