UCM/CBus2 7.042 (Beta) Upgrade - Printable Version
+--- Forum: CBus (https://www.comfortforums.com/forum-11.html)
+---- Forum: UCM/CBUS Firmware (https://www.comfortforums.com/forum-85.html)
+---- Thread: UCM/CBus2 7.042 (Beta) Upgrade (/thread-3758.html)
- Howser - 04-07-2014
I upgraded my UCM/Cbus to 7.041 without any issues. I then tried to upgrade to 7.042, the upgrade process goes all the way to where a rescan is done and the firmware remains 7.041 (tried a few times).
I am using Configurator 3.85, and I have bought and installed (while the UCM was off) the 24LC65 into the U2 socket (socket was empty).
- ident - 04-07-2014
Can you reset the Comfort and try the scan again
Comfort may be using the old value of the module in memory instead of querying the new UCM/CBus2
Thank you. Did Panel reset, and all is well.
