UCM/Cbus2 v7.052/7.054 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: CBus (https://www.comfortforums.com/forum-11.html) +---- Forum: UCM/CBUS Firmware (https://www.comfortforums.com/forum-85.html) +---- Thread: UCM/Cbus2 v7.052/7.054 (/thread-3874.html) |
- ident - 07-05-2014 The new 7.052 (Beta) firmware has the following changes Fixed a problem when messages are sent from a remote network via a Bridge, that causes the initialisation commands to be sent to Cbus. This causes the lighting status to be requested so that groups which are dimmed (level 1 to 255) cause the mapped counter in Comfort to change to 255. The bridged cbus command now does not cause a cbus to be reinitialised, instead it is ignored if the cbus mesage is meant for another network If the cbus is reinitialised due to an unexpected state of the SIM, it will not request the Lighting status again so the problem of counters changing to 255 when the lighting is dimmed will not occur Known Issues Enable and Trigger application map to counter does not work Firmware can be downloaded from https://www.cytech.biz/ucmcbus2_firmware.html - ident - 07-31-2014 UCM/Cbus firmware 7.054 (Beta) has the following changes;
- ident - 08-05-2014 UCM/Cbus2 firmware 7.054 has been released Upgrade in Comfigurator by right clicking on the UCM/CBUS2 in Modules and selecting \"Check for Updates\" An Internet connection is needed |
