telephone wiring - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html) +--- Thread: telephone wiring (/thread-4137.html) |
- dpickup - 02-24-2015 Hi All, due to renovations i needed to rewire my phone lines inside the house and i\'ve \"broken\" Comfort ! I have ADSL filter plugged in to the master socket and from the filter connected the TEL IN on comfort using pins 2 and 5 of the BT plug (does it matter which way round these connect to the TEL IN sockets ? I couldn\'t find anything in the install sections saying which goes where?) then TEL OUT goes to a BT type socket where I plug in my house phones in a daisy chain fashion when i go to dial test (user menu 3,4,3) it says \"please hang up\" and then repeatedly tries to redial ( i can hear the DTMF tones form the keypad) every minute or so and has been doing this for over an hour) apart from when Comfort is dialing the house phones work fine when i completely disconnect house phones comfort still not getting a dial tone any suggestions ? Thanks in advance, David - Swiss-Toni - 02-24-2015 There are only two wires going in to comfort try it both ways, as long as you know what the original color of the wires going into comfort there should not be a problem. Also wires must go to comfort first then tellephones. - dpickup - 02-24-2015 thanks Toni swapped both in var combinations and didn\'t seem to make a difference, but logged in with comfigurator, tinkered with a few settings and did a selective write and this seemed to fix it suspect it just needed a reset of some form to get out of the redial loop plugged all the phones back in and everything is fine now - Swiss-Toni - 02-25-2015 Forgot to mention that Slychiu always talks about doing a rewrite, good to hear its sorted |
