" press 4 for home control menu" missing - Printable Version
+--- Thread: " press 4 for home control menu" missing (/thread-418.html)
- Home - 01-09-2007
The menu reads out the topics but not press 4 for home control - if 4 is pressed then the HC menu activates OK.
- slychiu - 01-09-2007
That is probably because you have not programmed \"1 for ..
If you do not program the control key 1, the home control menu is not read. This allows systems without home control to skip the home control menu announcement
- Home - 01-09-2007
Yes the menu has this programmed - ill send a copy over
- Guest - 01-11-2007
I believe you might have misunderstood the issue of Control Key and Control Group. Kindly refer to another post http://www.comfortforums.com/forum36/409.html for more details.
