UCM D9 and D10 LEDs - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: UCM Problems (https://www.comfortforums.com/forum-73.html) +---- Thread: UCM D9 and D10 LEDs (/thread-4293.html) |
- slychiu - 08-02-2015 The D9 (red) and D10 (Green) leds on a UCM must both be blinking continuously for normal operation. These show the RS485 communications. D10 (Green) is the received message and D9 (red) is the transmitted message If D9 Red led is off it means that the UCM ID is not polled by Comfort. This is normally due to an ID issue. Check the ID of the UCM, and do a Scan for UCMs in Comfigurator If D10 Green Led is off, it means that the RS485 (KA and KB) signals are not connected to Comfort. The video shows the D9 and D10 leds on the UCM https://youtu.be/FoM9ZKqVt0o The Green led may appear to be on steady due to very fast blinking How to change the UCM ID here http://www.comfortforums.com/forum4/3418.html |
