Zone inputs screen - greyed out - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Zone inputs screen - greyed out (/thread-4342.html) |
- Home - 10-15-2015 I posted a year or so ago the suggestion that the zone input and related screens should be background highlighted at the change over from main board to slave ( for clarity reasons) I notice that when using the LEM03 the greyed out area still shows Z1-16 ( white background) and then Z17-32 ( light grey back ground)..... Obviously this is \"incorrect\". Ar you able ( on the LEM03 tick box) able to grey out the appropriate ( say) Z9 - Z24 thus better reflecting the divide between the main board zones Z1-Z8 and the LEM03 Z9-Z24 Thanks - ident - 10-15-2015 Yes that could probably be done as well |
