Is it possible to Disable noises - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort Android App (https://www.comfortforums.com/forum-110.html) +--- Thread: Is it possible to Disable noises (/thread-4501.html) |
- John W - 08-23-2016 As the title suggests. I\'m running v1.7 on a Samsung tab S.I have key press beeps disabled, and volume set to mute. Despite this, The app clicks loudly when logging in / out, and beeps loudly too when logging in. Is the beep a warning ?If so, how do I find out what the problem is. Many thanks, John. - slychiu - 08-24-2016 I believe this is indication of connection and is not a key beep sound. It is so that you can be informes that it has connected or diconnected - CYMD - 08-24-2016 It is media sound,you can disable or reduce the level in setting /sound/level/media - John W - 08-24-2016 Okay, thanks. So basically there is no application level control of this. Personally I would prefer this, as I want some things such as receiving a message to give an audible notification, but don\'t need a beep when I log in/out. Maybe you could add that to the future features list please.
- strickers - 08-25-2016 +1. This can get annoying and I dont want to turn down other media sounds so an volume level (or disable) in the app would be great
- slychiu - 08-26-2016 Noted |
