Comfigurator 3.11.13 - Printable Version
+---- Thread: Comfigurator 3.11.13 (/thread-4682.html)
- slychiu - 04-27-2017
Comfigurator  3.11.13 has the following changes
Known Issues
  1. IRIO- ISM03 - Input Function Current Sensor mapped to Comfort Sensors - Sensor references are not shown or displayed in Blue
  2. IRIO - ISM07 - Input Functions Analog Input and Resistive Sensor mapped to Comfort Sensors - Sensor references are not shown or displayed in Blue
Modbus Configurator
  1. For Comfort to Modbus, the Comfort registers for Discrete Inputs added Output, Output Toggle, Output Pulse, Virtual Input, Counter, Sensor, Flag, Arm, Panic, Bypass zone.  Discrete Inputs and Input Registers now have the same Comfort register types
  2. Comfort Registers for Coils and Holding Registers are the same, ie Physical Input, Counter, Flag, Sensor. Holding Registers added Physical Inputs, Flags
  3. In Modbus to Comfort, when Comfort register is mapped to Modbus, the Show Status Box allows the Comfort register eg Counter, Flag to show the real time value (allowing the comfort register changes due to modbus to be seen), and allows the value of the register  to changed in the status box (allowing the effect in Modbus Registers to be tested).
Upgrade Firmware by UCMJ Programming Cable
  1. For the process of upgrading firmware by UCM programming cable, when the upgrade fails or succeeds, the message \"Scan for Modules Yes/No\" at the end has been  removed. This is because Scan for modules does not work while UCM programming cable is connected, and the message leads to users attemting to scan for modules and failing
Alternative Phrases on Control Menu
  1. In previous Comfigurator versions,  we can enter alternative phrases in Control Group, Control Key and Control actions.However if the Phrase words are empty, the Control menu does not show the group, key or action and they appear as empty.Alternative Phrase is now displayed in the Control menu list if the phrase words are empty. In fact even if there is both alternative phrase and Phrase words, the Alternative Phrase should take precedence. This is to make it easier to create the control menu when the voice menu is not needed eg for the comfort apps or for Logic Engine LGX01 and UCM/Logic which do not have voice
HIO
Added Properties for
  1. Doorbell Occupancy Hold Time,
  2. Window A/C Off Dim Level 1,
  3. Window A/C Off Dim Level 2
  4. Occupancy Off Dim level 1,
  5. Occupancy Off Dim level 2
IRIO
  1. Relay I/O added Input Function Analog Input
KT05
  1. Added new Keypad type
- slychiu - 05-10-2017
Comfigurator 3.11.3 has been released
Please upgrade
- carlford - 07-12-2017
Maybe this is because I have an old comfort1 but when I use config 3.11.13 and write up a response with a condition of \" = \" the program puts 68 instead of 67 in the action code bar at the bottom of the left pane. Do you guys think this due to the older UCM coupled with the old comfort1 causes this or does the program of 3.11.13 do this for comforts 2 and 3 as well ???  Thanks in advance  Carl
- carlford - 07-13-2017
I am having a senior moment.  Went back to Config 2.2.3 and it does the same.  I guess I forgot as I thought 68 was \" <> \" and not  \" = \"  and 67 was  \" = \"  not <>.  My bad.  Carl
