removing scs switches from comfort - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Scene Control Switches (OBSOLETE) (https://www.comfortforums.com/forum-57.html) +--- Thread: removing scs switches from comfort (/thread-4705.html) |
- wexfordman - 06-20-2017 Hi, I have 4 scs switches, but two of them are no longer used so I need to remove them from my configurataion. I go to modules and settings, delete the removed ones, and then do a selective upload to update modules and setting. However, once I do this, and then do a scan for all modules, comfort still detects 4 scs switches, even though two are removed, so it should only detect the remaining two ? Would appreciate some quick advice on this, heading away tomorrow, so just want to get the comms failure cleared. Regards,Eamon - slychiu - 06-20-2017 When you removed the SCS from the configuration did you also remove them from the system physically and change the ID setting so that the remianing ones are ID 1 and 2? If the SCS remain connected then Comfigurator will detect them and add them again - wexfordman - 06-20-2017 Hi, the scs are removed, but I didn\'t change the IDs of the remaining ones so that might be the problem |
