Comfort with KNX in Victoria Park Villas, Singapore - Printable Version
+-- Forum: Comfort Around The World (https://www.comfortforums.com/forum-6.html)
+--- Forum: Comfort Case Studies and Installations (https://www.comfortforums.com/forum-54.html)
+--- Thread: Comfort with KNX in Victoria Park Villas, Singapore (/thread-4776.html)
- slychiu - 10-28-2017
Victoria Park Villas by Capitaland consists of 109 Units (106 Semi-Detached & 3 Bungalows) in Coronation Road, Singapore. Comfort Security with KNX Lighting controls from ABB are installed for all houses in the project.
Comfort Equipment installed:
  • CP9000-ULT Comfort Controller
  • KP04A-WI LCD Keypad, vertical
  • LEM01 Local Expansion Module
  • UCM/KNX2 KNX interface
website: http://victoriaparkvillas-capitaland.info/index.php
Images are from Victoria Park Villas website
More Info;
  • Designed by 3 independent architects leaded by Master Architect Mok Wei Wei from W Architects.
  •  A combination of different yet cohesively design houses that fully maximizes the land plot configuration.
  • Fully covered basement carpark with direct access from road level.
  • ​Private lift to all levels.
  • ​Fully equipped kitchen with quality appliances by Miele.
  • ​En-suite bathrooms for all bedroom.
  • ​[color=\"#ff0000\"]Home automation and security systems. [/color]
  • (Lights, airconditioning, water heater, garage door, CCTV, motion detectors)
  • ​Swimming Pool limited to only 6 Semi-Detached and 3 Bungalows.
  • ​Possibility of combining adjacent units for extended families purchases.
